iscsiadm: No portals found
Discussion about iSCSI Target.
IvanProtsenko
Post by IvanProtsenko »
Model U12-423
TOS version: 5.1.29-00343
iSCSI Manage version 2.5.54
I have created Target and associated a LUN with it.
One of ethernet port is dedicated specifically for iSCSI
Initiator also has a dedicated network adapter with an IP (10.61.16.233) on the same subnet.
I can successfully telnet from the Initiator to the Target IP port 3260. But
iscsiadm -m discovery -t st -p 10.61.18.233
returns
I tried iscsiadm -m discovery -t st -p 10.61.18.233 from TNAS itself (over ssh) with the same result. Can anyone point me in right direction?
TMwuu
Re: iscsiadm: No portals found
Post by TMwuu »
{L_BUTTON_AT}IvanProtsenko
Your problem has not been reproduced in our lab, can you make an appointment for a technical engineer to check it remotely for you? You can find contact details in my signature.
IvanProtsenko
Thank you. I'll try to contact a technical engineer next week. I think it is something with the network on this particular NAS. We have another U12-423 and I have no problems connecting it from same Initiator
mossholderm
Post by mossholderm »
Try setting it to use "All network interfaces", rather than just LAN1. I have had similar issues under TOS5.1, where enabling just one NIC in the target settings results in no access to ISCSI.
Return to “iSCSI Target”
