Request: Designate/Allow "Internal" Shared Folders
Tell us your most wanted new features, or recommendation.
LudivousKain
Post by LudivousKain »
It would be amazing if there were some way to add folders from one login/share to others without needing to either manually copy/move folders after they're synchronized or create multiple backup/sync jobs to separate shares. In my use case, I sync my desktops to my F5-422 with different user accounts. It would be a fantastic addition if there were some way to then share selected directories to the 'public' share when the folders are deep within another private share.
Feature Request: Please add some way to give read-only access to selected files/folders/subfolders to the guest login shares without it including the entire share.
Re: Request: Designate/Allow "Internal" Shared Folders
You can use the "Share" feature in the File Manager.
Return to “New Features Wanted”
