Bios/bootini version 5.19
In the download section for my nas it says.
Bootloader 5.1.42
Is this an update or a rescue thingy?
If its an update how do you apply it. There no comments on what it is..
How to update bios/bootini?
Re: How to update bios/bootini?
The bios does not need to be updated.The version of the bios is not directly related to the version of the Bootloader , which is used for system initialization.
- epsilonion
Ah OK so I don't need to update the nas with the iso file then?
{L_BUTTON_AT}epsilonion
Yes, it is not needed.
- plantarprofile
Set the file system of a USB flash device to FAT32. Because the formatting process will destroy all data on the drive, make sure it is empty or does not contain any vital files.epsilonion wrote: ↑22 Mar 2023, 18:39 Bios/bootini version 5.19
Bootloader 5.1.42
