New TerraMaster F5-221 Drive Issue.
I bought a brand new F5-221 with a Seagate IronWolf 6TB Drive (https://www.amazon.co.uk/Seagate-IronWo ... B085Z4P89R), i have a problem with the drive however. I have put it in what i think was properly and the HDD 1 light is green but when i try to setup the machine it tells me the drive is at risk and fails the setup, if anybody could help that would be great.
Re: New TerraMaster F5-221 Drive Issue.
Before installing the TOS, the system block on the drive will be scanned for the bad block. when you have a prompt drive at risk, this means bad block found on you drive, You better replace a drive and try again.
