VPN auto connect after restart
Tell us your most wanted new features, or recommendation.
Fdq
Post by Fdq »
IHi.
Is it possible to add the option to auto connect a VPN connection after a restart?
Currently there is the option to reconnect if disconnected, but the VPN is not connected by default.
Thanks!
TMRyan
Re: VPN auto connect after restart
Post by TMRyan »
We are solving this problem, and the reconnection of one VPN connection mode is still being solved.
You can try to update to TOS 5.1.22. If the connection method you choose fails to reconnect, you need to wait for us to update.
Fdq
Post by Fdq »
Thanks!
Reconnect if the VPN connection gets dropped actually seems to work.
Except if the NAS goes to power save mode because the UPS is running on low battery.
But my point was related to the NAS restarting after a power off: in that case I have to connect the VPN manually.
Thanks!
Return to “New Features Wanted”
