[ OctoPrint ] The snappy web interface for your 3D printer
About: https://octoprint.org/
Category: Utilities
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.12 or later versions
App download: https://tmnascommunity.eu/download/octoprint/
Required packages:
Python310 > 3.10.5.0
TOS4: http(s)://yournasip:port/modules/OctoPrint/www
TOS5: click on Support & Help from app description inside the App Center
About:
Full remote control & monitoring
Control and monitor every aspect of your 3D printer and your printing jobs right from within your browser.
Control and monitor every aspect of your 3D printer and your printing jobs right from within your browser:
Access the embedded webcam feed and watch remotely how your printer is creating your newest thing.
Get constant feedback regarding the current progress of your print job.
Take a look at the integrated GCODE visualizer to see a rendition of the GCODE you are currently printing.
Keep an eye on the temperatures of your hotends and print bed and adapt them on the fly.
Move the print head along all axes, extrude, retract or just define your own custom controls.
Start, stop or just pause your current print job, you are in full control at any time.
Compatible and extendable
OctoPrint's powerful plugin system allows extending its functionality with awesome plugins from the community.
scout71
Italy
Re: [ OctoPrint ] The snappy web interface for your 3D printer
Post by scout71 »
In the meantime, thank you for your hard work! I ask you one thing, in this case the NAS must be connected to the printer via USB right?
I suppose serial connection should work also if you have a usb2serial adapter that is well detected by NAS
pasqpe
Post by pasqpe »
I'm a newbie.
I have Octoprint installed on a Raspberry Pi4 and connected and running fine with an Ender 3.
I wanted to centralize everything on a NAS and for this purpose I bought a F2-220 and upgraded it to TOS 5.1.24.
I have read that the F2-220 is not compatible with this version of Octoprint but despite this I installed it :D
Octoprint starts but doesn't connect to printer: no ttyUSBx in tty list.
There are only ttySx but the connection is not made.
Can you help me?
Thanks for your works
Pasquale
Try to install the additional kernel drivers
viewtopic.php?f=37&t=2689
After you install/setup the kernel drivers, if you have knowledge on connecting with SSH to your NAS, run this command after you connect the printer
dmesg
Send me the result
pasqpe
Post by pasqpe »
outkastm wrote: 25 Mar 2023, 00:30 Try to install the additional kernel drivers
After you install/setup the kernel drivers, if you have knowledge on connecting with SSH to your NAS, run this command after you cnnect the printer
dmesg
Send me the result
Yes, I know how to use SSH.
As soon as I'm done I'll send you everything.
THANK YOU!
pasqpe
Post by pasqpe »
dmesg
Send me the result
Hi outkastm,
there's a problem!
The dmesg's result is too big: Your message contains 64287 characters.
The maximum number of allowed characters is 15000.
Are you interested in some sections?
pasqpe
Post by pasqpe »
Now all it's OKKKKKKK
THANKSSSSSSS :D :D :D :D :D
If it works i don't need the dmesg log :D
bretwashere
Post by bretwashere »
You cannot map the USB port to OctoPrint directly, only a serial port. I am going to play with this a little over the week, and see what I come up with...
