About:
Category:
Applicable TOS5: 5.1.12 or later versions
App download: https://tmnascommunity.eu/download/miniflux/
Required packages:
PostgreSQL_okm > 14.6.0.0
pgAdminOKM > 6.17.0.0
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5: click on Support & Help from app description inside the App Center
The app need to be configured before running succesfully:
1. Create the required database/username in PostgreSQL following this guide
2. Use SSH terminal (putty or web terminal app for TOS5 ttyd) to create the admin user required to connect to Miniflux app
3. Go to App WebUI menu Configuration files > Edit miniflux.conf and adapt the database name, user and password (previously created on step 1)
Start the app
Summary
Optimized for readability
The page layout, fonts, and colors are chosen to be readable on a screen. The most important thing is the content.
Download original article contents
Do you have feeds that display only a summary? Fetch the original article automatically.
No fancy features
I suppose you don't like bloated software? Miniflux focuses on simplicity. Less is more!
Fast and efficient
Be productive, use the keyboard shortcuts to navigate through the application. Scan quickly your unread items with the lightweight user interface.
Your privacy is guaranteed
Nobody resells your private data or track your usage.
No advertising and user tracking
Miniflux removes automatically pixel trackers.
Super simple installation
Miniflux is compiled statically without external dependencies, drop the binary on your server and you are done. You also have the choice to use the RPM/Debian package or the Docker image.
Free, open source and self-hosted
Miniflux is a free and open source project distributed under the permissive Apache 2.0 License.
