TOS 5.1 F5-221 CPU 100%
cipe91
Italy
Post by cipe91 »
Hello i report the issue in object.
The strange thing is this: i cant see any process who are using all the CPU.
Please help me.
F5-221
TMnorah
Re: TOS 5.1 F5-221 CPU 100%
Post by TMnorah »
Please open the Control Panel>System Resources>Process, click CPU to sort the CPU from high to low.
cipe91
Italy
Post by cipe91 »
Attacched.
"Processore" is italian CPU :lol:
F5-221
cipe91
Italy
Post by cipe91 »
{L_BUTTON_AT}TMnorah
Please consider this. i just tryed to restart it (and maybe clean some process). doesn't worked
F5-221
Mizuma
Post by Mizuma »
{L_BUTTON_AT}cipe91
(Not a TM employee) Could you try logging into SSH and using the command
top
? It will show you the running processes, CPU/RAM use, etc - try and look through this to see which ones are using a lot of CPU.
jhalfhide
Post by jhalfhide »
I had the same issue whereby the culprit wasn't showing in Processes. To find the issue, I had to look in Services > Service Resource Occupation.
Once I looked in there, I could see the BTRFS Cleaner was taking up 100%. This was caused by the automatic BTRFS snapshot in 'Backup'. I disabled this snapshot and my NAS has been running fine since.
F2-422 running TOS 5.1
Plex/Sonarr/Radarr/Lidarr/SabNZBD
jhalfhide
Post by jhalfhide »
Cancel that, not completely cured. Just doesn't go to 100% every hour now. Doing any read/write on the disc still results in BTRFS Cleaner hogging all the resources and basically crashing TOS
{L_BUTTON_AT}jhalfhide
It is likely due to the TNAS performing a quota check. The TNAS may take some time doing a quota check. This quota check should only run once after upgrading as long as it is able to complete successfully. Rebooting your TNAS might cause the quota check to restart from the beginning. Please allow it some time to finish.
Return to “System Resources”
