Now I've read the upgrade details I can see that TOS 5.1 is ready yet for my model of NAS.
So It's my fault. I'll try and work out how to go back. Please feel free to delete this request.
TOS 5.1 Beta is released for testing NOW!
- andrewfarquhar
Re: TOS 5.1 Beta is released for testing NOW!
{L_BUTTON_AT}REBELinBLUE
No need to pretend anything, no updated news means that there is no news yet. Please note that the new ARM 211 series models have also been delayed.
- REBELinBLUE
OK thank you, it's just that when the question has been asked about whether the arm models would (eventually) be supported no one ever answered
No chance, have now tested the 3rd HDD. Tested Edge, Firefox.
By the way, clearing the cache in the browser gives 0 points if the /vat/update folder still exists.
The update is uploaded, unpacked and then it doesn't go any further.
Sorry, but how should I describe something more precisely when the only indication is that the update failed.
I made you a screenshot, wrote down the model + announced the firmware and already told you that he would upload it, unpack it and then the /var/update folder would be there and you would not be able to update it a second time (regardless of whether the cache was cleaned is used or another browser is used). This only works after a reboot because the /var/update folder is already there. If the folder is deleted, then I can upload the update again and it does the same procedure. what else do you want Should I analyze the error for you why it doesn't work?
You are the support not me.
So dear support, I had the fun of installing the 3 HDDs in my F5-221 and lo and behold, the update went through all 3 HDDs without any problems. Then I tested it again in my F2-221 and the software runs there too. Apparently there are problems with the update routine. The difference is the BIOS. Perhaps there is a BIOS query that is preventing the update.
Error with 5.12 Bios
https://prnt.sc/9chlYq0XIu-b
succesful with MAPL0304V22
https://prnt.sc/mEOi7Q63k5e_
Sorry, here is the correct screenshot. Your software has problem wit _ at the end from a link.
https://prnt.sc/o86UUP5qjf1I
when is there going to be a TOS 5.1 (ARM) release for the f2-210.
If I knew you people wern't going to support your product I wouldn't have bought it.
- crisisacting
There's TOS 5 on ARM for the new/forthcoming 211 series, so if they are able to backport that to the 210 series, they could eventually release it publicly.
Terra-Master does continue to support the TOS 4.× builds (they released one just about a month ago), so it's not abandoned, just not on the newer TOS 5/5.1 releases, yet.
