TOS 4.2.40 is Released for Update
Gandalf1369
Re: TOS 4.2.40 is released for update
Post by Gandalf1369 »
Thank you @sianderson for your reply. I have been updating the Plex Media Server routinely while on TOS 4.29 with no problems. I use the .tpk file downloaded directly from the Plex website.
I am still interested to hear from any user who has updated his NAS from TOS 4.29 to 4.30 and uses PMS. Any problems or difficulties ??
Thanks . . .
ozhoo
Post by ozhoo »
Came from 4.2.31-2203011629 on an F2-210 and it worked great. Plex still works fine and I'm finally able to browse the app store. Thanks for the update.
seajayshome
Post by seajayshome »
> update.
Same on F4-220, upgraded 4.2.31 -> 4.2.40, Plex working fine.
doktorg@aol.com
Post by doktorg@aol.com »
Came from 4.2.31 to 4.2.40-2203011629. Plex is running fine, but the app store still doesn't show the updates Plex is saying are available.
ozhoo
Post by ozhoo »
doktorg@aol.com wrote:
> ...Plex is running fine, but the app
You can download the plex update from the plex interface then Manually install it through the TOS interface. Strangely enough, after that the App store will show the update as available even though it was just installed.
rick57
Post by rick57 »
Have just updated to 4.2.40 and have no issues with Plex media server but mine was installed from Terramaster app download rather than App folder as i have never had Apps in my App folder after setting up F2-210 from new so i've just been downloading from Terramaster,maybe they are a different version or just not Buggy,maybe try it?
doktorg@aol.com
Yeah, I fell for that. Did exactly as you describe and went further to apply the 'update' so the app folder and my install would be in sync. The 'update' was a downgrade to the previous version.
CapCaveman
Post by CapCaveman »
Is the link down? Shows this:
https://download2.terra-master.com/TOS_ ... 220940.bz2
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>UserDisable</Code>
<Message>UserDisable</Message>
<RequestId>63B0C06F9BA4CD4EC0689268</RequestId>
<HostId>download2.terra-master.com</HostId>
</Error>
sorry! the server was running abnormally yesterday, it is back in operation now.
oliv3rtwi5t
Post by oliv3rtwi5t »
Update fails manually.
Updating from 4.2.31-2203011629
Online updated failed, then the manual update failed.
It did however completely remove the Emby application. Thank for that....
