TOS 4.2.40 is Released for Update
TOS 4.2.40 Release Notes
Applicable models:
x86:
F2-220, F2-221, F2-223, F2-420, F2-421, F2-422, F2-423,
F4-220, F4-221, F4-223, F4-420, F4-421, F4-422, F4-423,
F5-220, F5-221, F5-225, F5-420, F5-421, F5-422,
F8-421, F8-422
arm:
F2-210, F4-210
1. Solved the issue that the app center could not load applications.(If you still cannot see the application after updating, please refresh the browser or clear the browser cache.)
2.Increased the timeout period for sending mails
3.Added U4-423,U8-423,U12-423 model related drive
4.Solves some issues of the domain/LDAP.
5.Solved some issues of file managemer.
6.Optimized some Settings for Rsync backup and domain user permissions
Important Notes
1. This update is only for TOS 4.1.31 or later versions. If your TOS version is earlier than TOS 4.1.31, please refer to here.
How to update your TOS?
Online update:
1. Go to TOS > Control Panel > General settings > Software update;
2. Check the option "Online update", click "Apply";
3. Follow the prompt to finish the update;
Manual update:
If the check for updates fails, please download the .bz2 package for manual update.
1. Download the update package:
Update package for x.86 models(md5=c4f4444da48cd02f7114f695d7b9828a)
Update package for arm models(md5=b3f2a1f126903f6521c6f3dcdf5a844f)
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
Issue report
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
macmpi
Re: TOS 4.2.40 is released for update
Post by macmpi »
Does it finally embed netatalk 3.1.13 to fix all the related known CVEs?
viewtopic.php?f=24&t=3253
onemeshnig
Post by onemeshnig »
F4-210 TOS 4.2.40 Cant change wallpaper
https://i.imgur.com/bXGAdFu.png
PriestyUK
Post by PriestyUK »
Updated and lost all my instlled applications, re installed emby and now it won't start. FML. How do I fix?
sianderson
Post by sianderson »
updated, no issues to report, all apps are still visible and working upon reboot
only frustration is the DLNA media server needs to rescan the folders and re-create its media list everytime the unit is booted up, in my eyes this is unessessary processing power as it should retain its media list upon a reboot
macmpi
Post by macmpi »
@sianderson: can you check netatalk version under ssh, please?
sianderson
do you have more detailed info on how to do this, i have checked the afp.conf file as well as the global one, there doesnt seem to be any hint of a version number (happy to SSH to the nas drive, but dont know what to do after that)
Saijin_Naib
Post by Saijin_Naib »
macmpi wrote:
Considering they still have not fixed the inability to use any WiFi SSID with spaces that I reported years ago, I doubt they updated any platform libraries.
Gandalf1369
Post by Gandalf1369 »
After updating from 4.2.39 to 4.2.40 is anyone having issues or problems with Plex Media Server?? Does PMS work properly after rebooting??
sianderson
i used to have awful problems with plex after any update, so much so i gave up using it, i found the DLNA media server app much easier to get on with i know it doesnt have transcoding ability so i have to manually encode the media correctly, but to be honest i record off the TV with a HDMI recorder so that does MP4's which is natively supported
