I cannot properly automate my backups with shell scripts because the version of the find utility on the system is ancient, and does not support "-mtime" so I cannot delete old backup files, and I cannot install any x86 compiled version of 7-zip because it requires at least libstdc++.so >= version 6.0.25 and this system only uses 6.0.20, which is ancient.
It would be much appreciated if a newer release would update these ancient library versions, however this may require re-compiling the base system as I was unable to update just the library file and boot successfully afterwards.
ARM: Update ancient system library files and utilities (libstdc++, find)
- RedScourge
- Saijin_Naib
Re: ARM: Update ancient system library files and utilities (libstdc++, find)
I agree. It looks like the fork of OpenWRT we're using on TOS 4.x ARM is from somewhere around 2018/2019, unless I'm terribly off (I don't think I am).
