I have two tasks running on USB Copy, both mirroring folders onto the destination drive. One of them is about 1GB in size and the other is 170GB. This data is being backed up onto a 256GB drive. However, I get the status 'partially completed' and when I check the drive capacity it's showing as full? This can't be correct - there is no other data on the destination drive other than the USB copy tasks so what is happening?
USB Copy:
USB Storage:
Joe
USB drive full error?
Re: USB drive full error?
You can plug the USB to your computer to verify if it is full or not.
Yeah, I've done that and I can verify it's full (0% free space) but there is only ~111GB data stored on it.
I started with an empty drive, I plugged it into the NAS and ran two tasks as in the original post, and I got the 'partially completed' status report. The NAS has filled the drive but not with all my photos!
Have you set up a multi-version backup, and backed up more than once?
You can view the capacity of the folder in the properties of the file manager.
No it's a mirror backup. The combined data in both folders is about 171GB, which should easily fit on the 256GB drive.
I can confirm a similar issue. VIA File Manager, I've 1.81 TB out of the 3.64 TB HDD plugged in via USB.
However in Control Panel, it shows only 50.88MB/3.64 TB is free.
This happened before with the TOS 5.0 Backup app, so I tried with USB Copy, unfortunately the same issue arises.
Both folders set to MIRROR.
