Emby wont load?
Emby wont load?
Both my machines are F5-221s and one is running the latest TOS 5 and the other TOS I have re-installed Emby on both and on the TOS 5 machine all I get is a 404 error when I try and launch, and just a screen saying Emby on the TOS 4 machine what's wrong?
Re: Emby wont load?
Would you give me a screenshot about this error? so that we can see what other information showing there. Did you install and then uninstall any app before the issue happens? what are the apps you uninstalled?
Re: Emby wont load?
No, only tried uninstalling and re-installing Emby after getting this (see screenshot) and just an error 502, if I try to start Emby from the app page it returns error.
Re: Emby wont load?
Hello, you can try to go to the control panel - shared folders, change the name of the emby folder, and then reinstall emby.
Re: Emby wont load?
I am confused. I did not see 502 error message, it is a startup page of the app, and the emby screenshot is the version for TOS 4, not TOS 5.
