I am running Emby Server on one of my F2-221 NAS devices.
It appears the is something corrupt in the database as I have two Collections showing but it is only one really. I have tried everything to cure it to no avail.
So I uninstalled Emby from Terra-Master Apps, restarted the NAS and reinstalled Emby, but got a bit of a shock it was full of all the existing data as it was before I uninstalled. I cannot find any way to find or delete any data associated with Apps, So how do I do a clean install of Emby Server?
Clean Install of Emby Server
Re: Clean Install of Emby Server
I guess the EMBY team can provide better help for this issue.
I could probably sort it myself if I could see the Emby Server data files on my NAS.
Terra-Master File Manager will not show me any system files or App files, it looks like they are blocked, I can't see in system settings how to allow access.
I have looked for an alternative more comprehensive File Explorer in the Apps list but there is not any others..
I need to see and maybe delete to fix my problem:
/mnt/md0/application/emby/system
/home/emby/cache
/home/emby/metadata
There is no way currently to expose them!
So I'm still stuck!!
/home/emby/cache
/home/emby/metadata
You can find the emby directory according to the prompt below.
This is just what I needed to find my way to the folder to solve my issue.
