VMs Crash on TOS5 5.0.126-00163
kennethmb
Post by kennethmb »
All VMs I try to run in virtual box ABEND this way.
I thought it was because I was bringing it forward after the TOS5 Update but I get the same thing when trying to create a new vm.
Exception Object
    [message:protected] => The virtual machine 'HomeAssistant' has terminated unexpectedly during startup with exit code 1 (0x1)
    [string:Exception:private] =>
    [code:protected] => 0
    [file:protected] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
    [line:protected] => 2443
    [trace:Exception:private] => Array
            [0] => Array
                    [file] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
                    [line] => 951
                    [function] => remote_progressGet
                    [class] => vboxconnector
                    [type] => ->
                    [args] => Array
                            [0] => Array
                                    [progress] => 11945766c42e0f31-0000000000000004
            [1] => Array
                    [file] => /Volume1/@apps/virtualbox/webui/endpoints/api.php
                    [line] => 316
                    [function] => __call
                    [type] => ->
                    [args] => Array
                            [0] => progressGet
                            [1] => Array
                                    [0] => Array
                                    [1] => Array
                                            [0] => Array
                                                    [data] => Array
                                                            [responseData] => Array
        [info] => Array
        [completed] => 1
        [canceled] =>
        [description] => Starting VM
        [operationDescription] => Creating process for virtual machine "HomeAssistant" (headless)
        [timeRemaining] => Array
        [timeElapsed] => Array
        [days] => 19175
        [hours] => 18
        [minutes] => 31
        [seconds] => 8
        [percent] => 0
                                                            [success] => 1
                                                            [key] => 53474945cfd7ac0bf8114767c209c2a6
                                                    [errors] => Array
                                                    [persist] => Array
                                                    [messages] => Array
    [previous:Exception:private] =>
Re: VMs Crash on TOS5 5.0.126-00163
what did you mean ABEND this way?
A new version of VirtualBox will be released next week, please try the new one.
kennethmb
Post by kennethmb »
abend abnormal end or crash
kennethmb
Post by kennethmb »
When will the new version of VirtualBox be released? Its been a month now and still no release of VirtualBox
The latest version was updated on July 18, have you installed it?
kennethmb
Post by kennethmb »
Yes I did and I still get this dump when it fails to boot
Exception Object
[message:protected] => The virtual machine 'Test' has terminated unexpectedly during startup with exit code 1 (0x1)
[0] => Array
[line] => 951
[type] => ->
[args] => Array
[0] => Array
[progress] => 198d9e1786b822bf-0000000000000005
[1] => Array
[line] => 316
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] => Array
[info] => Array
[completed] => 1
[canceled] =>
[operationDescription] => Creating process for virtual machine "Test" (headless)
[days] => 19208
[hours] => 21
[minutes] => 49
[seconds] => 23
[percent] => 0
[success] => 1
[errors] => Array
[persist] => Array
[messages] => Array
If convenient, you can contact our tech team to have a check.
Return to “Virtual Machines”
