Unable to use the TOS5 desktop
21alpha
Post by 21alpha »
Hi
Since TOS5 update to my F2-421 NAS device I applied showtdown and power up schedule. The TNAS unexpectidley shut itself down and now I am unable to access the desktop interface. I can login to the TNAS successfully but am unale to click on anything on the desktop. I have force restarted the TNAS and have cleared histroty from my browser and have tried different browsers but I cannot get passed the message on the desktop screen "Tips the device is shutting down"
Please see attached file.
Re: Unable to use the TOS5 desktop
Try 5.0.125, and let us know if the issue persists.
21alpha
Post by 21alpha »
Hi
I am using the latest firmware 5.0.125
The same issue was logged by another user here
viewtopic.php?f=81&t=3371&p=19363#p19363
I simply cannot do anything with the desktop
please advise
when you see this tips, your tnas has actually shut down or not?
21alpha
Post by 21alpha »
no. What happened was I updated to TOS 5.0.125 and then set a power shutdown and power startup schedule. The TNAS then automatically shutdown without me actually shutting down the system. When the system powered up and I logged in to the desktop and the message was on screen "Tips The device is shutting down".
Ive tried different browsers, cleared cache, history etc.. but when I login to the desktop the message is still there. It cannot be dismissed and I cannot click on anything on the TNAS desktop.
I have to say after having no issues with TOS 4x, this TOS5 has more holes in it than a T-Bag, its shocking, full of issues.
Do not worry, most of issues will be fixed within 1~2 weeks.
May I know what time you set to schedule power on/off, and what time it actually power on/off? if you press the power button to power it off manually and power it on again, does this issue still persists?
21alpha
Post by 21alpha »
shutdown at 23.59hrs and startup at 08.00hrs. Powered down around 12.30hrs today.
Ive powered the device off 3 times but still the same issue
Can login to the desktop fine but the tips message is still there, cannot be dismissed and I am unable to click or open anything on the TNAS desktop.
In another thread someone else reported the same issue and they were able ti fix it by updating the firmware. I am on th elatest firmware though and dont know how I oculd update to a later version once released if I am unable to do anything on the desktop.
we will send you a guide to collect some logs and information for us to study tomorrow.
21alpha
Post by 21alpha »
thanks
TMRyan
Post by TMRyan »
Can you now use your computer to map shared folders or log in using ssh?
How to log in using ssh: viewtopic.php?f=78&t=2350
