[ HomeAssistant ] Open source home automation
mokagino
Re: [ HomeAssistant ] Open source home automation
Post by mokagino »
wow!!!
Daywalker
France
Re: [ HomeAssistant ] [ 2022.6.5 ] Open source home automation
Post by Daywalker »
{L_BUTTON_AT}duberic
user222333 wrote: 24 Feb 2023, 01:35
outkastm wrote: 07 Aug 2022, 14:14 What add-ons do you need? Will be done as separate tpk files.
Hello Outkastm! Is it possible to install HACS (Home Assistant Community Store)?
Hi, Yes, can you add HACS add-on ? And I can't use advanced mode when I turn on toggle. Thanks
F5-422
psviteri
Post by psviteri »
There is a new version released in June.
Any chance of updating manually?
will this work?
https://home-assistant-china.github.io/ ... /updating/
2023.7.2 is available
NaNo
Post by NaNo »
Hello, is there a way to install home assistant on a F2-210? I cannot find a armv8 version of the package...
Not as a standalone app
TheOpsMgr
Post by TheOpsMgr »
I've tried installing the supplied package but I don't get the standard HA onboarding screen but go straight to the login page... what's the default username/password?
sharkietel
Post by sharkietel »
Hi! thanks for your help to have HAOS on Terramaster.
There are any posibility to have add-ons store?
And the new HA Versión fully working?
Thanks!
sharkietel wrote: 07 Jan 2024, 20:08 Hi! thanks for your help to have HAOS on Terramaster.
Thanks!
Not possible to have the add on on python version.
Which addon do you need? Most of them can be done as separate app
kainruben
Post by kainruben »
Hello, I am interested on install manually this addon
https://github.com/MislavMandaric/home- ... ant-vsmart
I have done the steps, but I can't see the vaillant integration.
Is possible install manually addons??
