Snapshot integration with Windows Explorer
TerraMaster Snapshot is a disaster recovery tool developed based on the BTRFS file system. Take snapshots of shared folders or iSCSI LUNs and quickly restore data after a disaster by taking advantage of file system features. In TOS 5, Snapshot has been redesigned to add more features and improve the user experience.
Spewk
Post by Spewk »
Hi all,
i'm succesfully using snapshot app in my TNAS with TOS 4.1.21
is there any way to integrate it within Windows Explorer?
I've succesfully done snapshot of some shares, but i can see them only in the Snapshot app, they're not visible from Explorer's "previous versions" as done on other filers
I know i can show them as a #snapshot folder, but i would like to know if an implementation of that type is ongoing
thank you
Daniele
Re: Snapshot integration with Windows Explorer
The snapshots would be visible with SMB access to TNAS once you have checked "Allow snapshot visible"
Spewk
Post by Spewk »
so no "previous version" in Windows Explorer implementation?
hi Spewk,
Snapshot in TNAS is supported by btrfs file system, it is not compatible with windows file system, so at present, this Snapshot is not able to work with Windows "recover from previous versions".
Spewk
Post by Spewk »
Ciao TMroy,
perfect! thank you for the explaination :)
Daniele
UncleJohnsBand
Post by UncleJohnsBand »
Are there plans to provide a windows explorer integration (previous versions) for the TNAS?
Sorry, not for the time being.
Return to “Snapshot”
