Boost your TNAS network bandwidth to 2.5G
TerraMaster has recently launched a USB 2.5G network adapter, which is connected to the USB 3.0 host interface of your TNAS to increase the bandwidth to 2.5Gbps. It is available for sale now.
Applicable models
x.86 series models: F2-220/F2-221/F4-220/F4-221/F4-420/F5-221/F5-421
ARM series models: F2-211/F4-211/U4-211
TOS requrement: 4.2.18 or later versions
Note: Because 220 series and 420 series TNAS have both USB 2.0 host and USB 3.0 host, if you are using 220 series and 420 series TNAS, please be sure to connect the network adapter to the USB 3.0 host port, otherwise, the network bandwidth will be limited.
Know more
demetry14
Re: Boost your TNAS network bandwidth to 2.5G
Post by demetry14 »
What chip does this USB LAN adapter use?
RonnyK
Post by RonnyK »
Shipping costs to the UK exceed the price of the item making this adaptor way too expensive (£70). I don't think that someone would be interested in buying it.
crisisacting
Post by crisisacting »
This person mentioned their CLUB3D adapter worked previously, which is RealTek based: viewtopic.php?f=12&t=1977
The Terra-Master branded one is most likely RTL8156B based.
21alpha
Post by 21alpha »
according to tech support it will be available to purchase from Amazon UK in the next 2 weeks once a batch has been shipped from China.
https://www.amazon.co.uk/dp/B0B12C877N?ref=myi_title_dp
adrian47uk
Post by adrian47uk »
> Applicable models: All TerraMaster TNAS models
> [url=https://www.terra-master.com/global/pro ... -2-5g.html]Know
> more[/url]
Will this work with the 210 series? i would have to update my network in the computer and get a new switch, but it may be worth it.,
TMRyan
Post by TMRyan »
Yes, it fits all TNAS models
adrian47uk
cheers, may be worth thinking about at some point, certainly if I change the computer to a Mac, I have just realised that I will need two 2.5Gb/s switches unless i can change the network around, we will see.
demetry14
Post by demetry14 »
I would appreciate a Terra-Master Support person response to this question. Your customers deserve to know basic information to make informed decisions.
RonT
Post by RonT »
I have 3 Fx-210's that says that statement is incorrect.
It has the Realtek chip.
