RonT wrote:
> Let me clarify that last comment,,,,,
I did not take it apart to see the chip but 2 devices reported it
to be a Reaktek chip.
Boost your TNAS network bandwidth to 2.5G
Re: Boost your TNAS network bandwidth to 2.5G
otherwise, the network bandwidth will be limited
Hiya
Just to let you know its been 2 & half months since Terramaster CS said the adapter would be available to purchase via Amazon UK (within 2 weeks) however, its still not in stock.
If I try to purchase it on the Terramaster UK site its over £30 just in shipping costs which is ridiculous.
Is there no stock in the UK?
Why extra USB dongle when F5-221 on-board Ethernet adapter's port 1 already supports 2.5G?
# ethtool enp2s0
Settings for enp2s0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
2500baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
master-slave cfg: preferred slave
master-slave status: slave
Port: Twisted Pair
PHYAD: 0
Transceiver: external
MDI-X: Unknown
Supports Wake-on: pumbg
Wake-on: d
Link detected: yes
- joergurmel
... ich hatte mir den Adapter extra für die F4-210 gekauft, da es hier als "für alle NAS Serien" angeboten wurde.
An der 210 funktioniert der Adapter aber nicht, wurde mir dann vom Support später bestätigt.
Wäre schön, das die Aussagen dann hier angepasst werden, oder mir einer verraten kann, wie der Adapter dann an der 210 funktioniert?
Ich finde die Aussage, das es an allen Geräten funktioniert, aber dann doch nicht, nicht sehr gut!
Oder gibt es einen Adapter(andere Hersteller?), der an der 210 unterstützt wird??
MFG Jörg
MFG Jörg
now available to buy for £29.99 on Amazon UK site
https://www.amazon.co.uk/dp/B0B12C877N? ... ct_details
- joergurmel
... ist aber mit Terramaster 210 nicht benutzbar!
- crisisacting
That Amazon UK listing does now state it's not compatible with the 210 series.
Does it even detect the USB adapter? SSH onto your 210 device & check to see if it's mounting:joergurmel wrote: ↑28 Nov 2022, 06:13 ... ich hatte mir den Adapter extra für die F4-210 gekauft, da es hier als "für alle NAS Serien" angeboten wurde.
lsusb
Also, the older kernel of TOS 4 may also be preventing the ability to install the network interface even if it is detecting the USB adapter.
- EricChandler
Can I ask if it can connect to yo whatsapp? I need your support
