SSD Overheat
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
great0dane
SSD Overheat
Post by great0dane »
I want to let you know on TOS 5.0.67 I am getting overheating warnings for my SSD where TOS is installed. The drive feels warm but not overheated. This disk is a Kingston SA400 120GB installed in F5-422.
Screenshot 2022-04-08 081111.png (22.51 KiB) Viewed 2444 times
Re: SSD Overheat
The disk temp is offered from the smart info.
Would you go to control panel > storage > hard drive > SMART, and create a SMART test task, then send us the SMART report? we will check if there is any thing wrong in the smart info.
great0dane
Re: SSD Overheat
Re: SSD Overheat
{L_BUTTON_AT}great0dane
Thank you for your feedback, we will fix it in the coming releases.
Return to “Compatibility”
