Backup From TerraMaster NAS To WD NAS Via Script Daily
Discuss understanding the various backup tools available and choosing the one that's right for you
LexMark2100
Post by LexMark2100 »
Hi TerraMaster,
I want to set up a backup of all Shares on my TerraMaster NAS to my WD NAS using a mounted Share on my TerraMaster NAS that points to my WD NAS that is scheduled to be carried out daily and will continue to run daily even if I restart my TerraMaster NAS. My WD NAS can use NFS if needed but it needs to be configured on the WD NAS.
How can I go about this by setting this up using SSH?
Please let me know.
Support is much appreciated!
Thanks,
LexMark2100 :)
Re: Backup From TerraMaster NAS To WD NAS Via Script Daily
Well, there are several options to back up your data from one nas to another.
The most popular options are
1. rsync backup; this require your WD NAS act like a rsync server, and find the backup entrance from the "Backup" section in your TOS;
2. TerraMaster Duple Backup; you need to install this app from terramaster App Store;
LexMark2100
I have tried RSync but unfortunately my WD NAS doesn't support it.
Duple Backup doesn't seem to work for me either over my local network.
Can you send me instructions on how to carry this out?
Thanks.
Thanks,
LexMark2100 :)
Hardfecx
Post by Hardfecx »
LexMark2100 wrote: 01 Apr 2022, 20:44 Hi,
Thanks.
That is interisting me too, I want just some Folders transfer over my local network to a smaller Nas. But can't find any software for that
TMRyan
Post by TMRyan »
Does your WD NAS support NFS remote mount?
If so, you just need to edit the shared folder, set the NFS permission to read and write, then use your WD NAS to mount it, and copy your files to the shared folder of the WD NAS after the mount is successful.
The backup method depends on which backup methods your WD NAS supports.
LexMark2100
My WD NAS only supports SMB and NFS.
Can you give me step by step instructions on how to set this up easily so that I do not have set up a schedule / remote folders / Shares for each and every Share that I have?
Thanks,
LexMark2100 :)
LexMark2100
LexMark2100 wrote: 01 Apr 2022, 23:13 Hi,
Or could you provide me with remote support to get this up and running?
Thanks,
LexMark2100 :)
We can share you our experience, but we are not able to support you set up a backup works with remote session. Sorry for that.
Hardfecx
Post by Hardfecx »
You are here not in an Western Digital Forum...
Return to “How to back up? Which one is right for me?”
