VPN Server - OpenVPN Setup problem
xbaeza
Post by xbaeza »
i'm trying to configure and access VPN Server but i'm unable to access.
I've configure VNP Server -> Open VPN, I've enabled Access to my user in the VPN Server panel, i've redirected ports on my router (1119 UDP, same as configuration) and clicked on the "Export configuration" button, but the resulting config file VPNConfig.ovpn is empty. Inside the zip there is also a txt file and a ca.crt that are OK.
I've try also to enable L2TP/IPSec but when I try to connect, i got a timeout error.
TerraMaste F2-420
Latest firmware
Tunnelblick to connect to OpenVPN (Mac)
What can I do?
Re: VPN Server - OpenVPN Setup problem
Please refer to the articel for troubleshooting: viewtopic.php?f=83&t=2821&p=15398&hilit ... %9F#p15398
xbaeza
Post by xbaeza »
Thanks for the tutorial, but when configuring OpenVPN, in the STEP 3, my file VPNConfig.ovpn is empty, so i can't use it to configure the VPN client.
Regards,
Xavi
Hi! It may be that the browser you used is preventing you from downloading the file, or that the file is opened incorrectly, please check.
xbaeza
Post by xbaeza »
Hi! I've reinstalled VPN Server app in the NAS and now I got the config file.
Now, i'm able to connect, but i can't see any other machine in the network. If I ping any address TIMEOUT occurs ... I've checked the "Allow clients to access the LAN" in the OpenVPN setting but it seems not to have any effect.
Any ideas?
Thanks!
TMAY
Post by TMAY »
Follow the instructions in the how-to guide:
Return to “Network”
