[ TeamSpeak3 ] VOIP server module
About: https://www.teamspeak.com
Category: Tools
Last version: 3.13.7.0
Applicable models: TerraMaster x.64 series
Applicable TOS5: 5.0.135 or later versions
App download:
https://tmnascommunity.eu/download/teamspeak3/
Required packages:
http(s)://yournasip:port/modules/TeamSpeak3/www
About :
TeamSpeak 3 offers the ideal voice communication tool for online gaming, education and training, internal business communication, and staying in touch with friends and family.
Our primary focus is delivering a solution that is easy to use, with high security standards, excellent voice quality, and low system and bandwidth usage.
With years of experience and leadership in VoIP since 2001, our engineers have delivered a flexible, powerful, and scalable solution allowing you the ability to customize and tailor your voice communication needs any way you desire.
TeamSpeak 3 offers the ideal tool for online gaming, education and training, internal business communication, and staying in touch with friends and family. Our primary focus is delivering a solution that is easy to use, with high security standards, excellent voice quality, and low system and bandwidth usage. Featuring a client-server architecture, TeamSpeak 3 is literally capable of handling up to thousands of simultaneous users.
How it works
Host your own TeamSpeak server or rent one from an Authorized TeamSpeak Host Provider. Share your TeamSpeak server address with anyone you want to speak with. They connect to your TeamSpeak server via the free desktop client using the server address you provided. Start talking. It’s that easy!
Voice Quality. TeamSpeak 3 uses the Opus audio codec delivering unmatched voice quality. Integrated automatic microphone volume adjustment, background noise reduction, and echo cancellation ensures crystal clear communication.
Scalability. Client-server architecture allows you to scale from small group conversations to large conferences with hundreds of participants.
Permissions. You have complete control of your TeamSpeak 3 server. With a powerful permission system, you decide: who can talk, who can join channels, who can remove users, and much more.
Security. AES based encryption can optionally be enabled for the entire server or specific channels on the server. Additionally, to avoid potential threats arising from weak usernames and passwords, TeamSpeak uses public-private key authentication.
Customization
. Customize your client to meet your own personal style with the included themes, soundpacks, and designs, or choose from hundreds of addons contributed by our TeamSpeak user community.
File Transfer. Maximize your online collaborative experience. Share and download files that are stored on the TeamSpeak 3 Server.
Mobile. Stay connected when you're on the go with our Android and iOS TeamSpeak apps.
Re: [ TeamSpeak3 ][ 3.13.6.0 ] VOIP server module
added initial version
PriestyUK
Post by PriestyUK »
Nice one thank you :)
Re: [ TeamSpeak3 ][ 3.13.7.0 ] VOIP server module
up to 3.13.7.0 and added TOS5 version
spanto
Post by spanto »
Hola, no puedo instalarlo en mi terramaster f2-210 siempre me da error.
olaz84
Post by olaz84 »
Wouldn't it be possible to have the arm version as well???
I have a terramaster f4-210.
And the currently available versions do not work.
Or am I doing something wrong?
Teamspeak cannot run on ARM platform.
olaz84
Re: [ TeamSpeak3 ] VOIP server module
Post by olaz84 »
Is there any way to install it?
If cannot run, definetly there is no way to install it.
