TOS update F5-420 4.2.28 and Virtual Box
Bernhard.Wuest
Post by Bernhard.Wuest »
Hello all.
I just read the desaster messages about the update when having Virtual Box installed.
For me it is no problem to uninstall VirtualBox before the update to 4.2.28
The question is: Is this all than is needed?? Or do I have to remove certain files to ensure the NAS does not see anything left from Virtual Box.
Secondly. Can I install VirtualBox after the TOS update or do I need to wait for an VirtualBox update.
gretor
Re: TOS update F5-420 4.2.28 and Virtual Box
Post by gretor »
Hello Bernhard.Wuest,
I had tested different scenarios on Friday for this. Even if you install Virtuel Box only after the TOS 4.2.28 patch, it comes to the serious crash. So it doesn't matter which way around. Never install Virtual Box and TOS 4.2.28 together !
We will have to wait for an update of either Virtual Box or TOS.
With kind regards
gretor
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
Bernhard.Wuest
Thanks.
Coming back to the first part of the question:
Is it ok to uninstall VirtualBox and then update the firmware or are there additional steps necesarry.
gretor
Post by gretor »
I had not tested this circumstance yet. I believe that it works. But I can not say it 100%.
TNAS F2-221 - TOS 5
4 GB Ram
Bernhard.Wuest
Well,
thanks but not really helpful. I would like to know if it is safe to update when Virtual Box is uninstalled actually.
Not sure is the answer I already gave to myself, that's why I thought lets ask the professionals :)
Obviously no one from TerraMaster likes to answer.
Gretor thanks for your answers anyway.
THanks
TMRyan
Post by TMRyan »
You can update VirtualBox before updating the system.
Or uninstall VirtualBox and then update the system, and then manually install VirtualBox in the update instructions after the update.
Release Notes: viewtopic.php?f=28&t=2906
VirtualBox that needs to be manually installed:VirtualBox download link
Bernhard.Wuest
many thanks for the reply. I have Virtual Box uninstalled and will firstly install the new TOS update
gretor
Post by gretor »
And the manual installation actually works without leaving any damage ?
Bernhard.Wuest have you tried it ?
TNAS F2-221 - TOS 5
4 GB Ram
Bernhard.Wuest
Yes. I uninstalled VirtualBox and then upgraded the firmware.
Havent reinstalled VirtualBox yet as I am not using it frequently.
In fact had problems in setting it up and havent taken up the attempt again.
All the best
Return to “Virtual Machines”
