[ Prowlarr ] Prowlarr is an indexer manager/proxy to integrate
About: https://github.com/Prowlarr/Prowlarr
Category: Indexer
Applicable TOS5: 5.1.12 or later versions
App download: https://tmnascommunity.eu/download/prowlarr/
Required packages:
http(s)://yournasip:port/modules/Prowlarr/www
About
Prowlarr is an indexer manager/proxy built on the popular *arr .net/reactjs base stack to integrate with your various PVR apps. Prowlarr supports management of both Torrent Trackers and Usenet Indexers. It integrates seamlessly with Lidarr, Mylar3, Radarr, Readarr, and Sonarr offering complete management of your indexers with no per app Indexer setup required (we do it all).
Major Features Include:
Usenet support for 24 indexers natively, including Headphones VIP
Usenet support for any Newznab compatible indexer via "Generic Newznab"
Torrent support for over 500 trackers with more added all the time
Torrent support for any Torznab compatible tracker via "Generic Torznab"
Support for custom YML definitions via Cardigann that includes JSON and XML parsing
Indexer Sync to Lidarr/Mylar3/Radarr/Readarr/Sonarr, so no manual configuration of the other applications are required
Indexer history and statistics
Manual searching of Trackers & Indexers at a category level
Parameter based manual searching
Support for pushing multiple releases at once directly to your download clients from Prowlarr
Indexer health and status notifications
Per Indexer proxy support (SOCKS4, SOCKS5, HTTP, Flaresolverr)
Re: [ Prowlarr ][ 0.1.8.1231.0 ] Prowlarr is an indexer manager/proxy to integrate
added initial version
Re: [ Prowlarr ] Prowlarr is an indexer manager/proxy to integrate
added TOS5 version
I have installed this on TOS5. However it won't launch.
When I check it says it isn't enabled. When I click enable it says 'operation failed'
Any ideas? I couldn't see any required packages to be installed first.
I'm so sorry, please ignore. Had to update TOS version
Before TOS 5 support was added i would run this through Docker. It had hundreds of indexers.
I have noticed in this release there are very few.?
