3rd party app request and work in progress
CraftyClown
Re: 3rd party app request and work in progress
Post by CraftyClown »
Got there in the end! Thank you, you sent me in the right direction.
It was the shared folder I was mounting the rclone directory into that needed the 'media' group permissions for Plex to see the mount. It's a little confusing as I didn't need to do that for any of the other shared folders Plex is accessing, but as long as it works im happy.
Regarding Wire guard, that's a shame. So I guess that is something Terramaster would need to make available within the kernal?
Have you worked on any other VPN servers for TOS?
CraftyClown
I decided to go with Tailscale in the end as I saw youd got it working and it's built off the back of Wireguard. Not as fast but should be fine for my purposes
predamail
Post by predamail »
@outkastm
Can you please add Calibre on the list of apps? The Docker image is running into issues way too often. Thanks
