Hi all,
today I wanted to create a Backup List (different Backups every day), but after creation of the Timeplanning and the confirmation that the planning has been created (Pic Unbekannt) I got this (Pic Unbekannt2).
But in the File Explorer of TOS, I can see the USB device and even create a folder on it (Pic Unbekannt3 & 4).
What I have seen too is that I choosed the Backup as Image and in the Option (after creating the Task), it is defined in Multiversions.
Has anybody an Idea?
Issue with USBCopy
Issue with USBCopy
- Attachments
- Unbenannt3.JPG (22.32 KiB) Viewed 3238 times
- (22.03 KiB) Not downloaded yet
- (19.12 KiB) Not downloaded yet
Re: Issue with USBCopy
Hi! Did you create a backup task before inserting the USB device? Please confirm that the USB device used when creating the backup task is the same as the one currently inserted.
Please try to safely remove and reinsert the USB device before creating a backup task.
The Usb drives were already inserted. I tried to create a new task and let it instantly run. I looked this morning and the task was completed and all files were copied.TMSupport wrote: ↑07 Nov 2021, 15:18 Hi! Did you create a backup task before inserting the USB device? Please confirm that the USB device used when creating the backup task is the same as the one currently inserted.
May someone explain to me why my 1,5 Tb are not copy 1-1 ond my USB HDDs?On then USB backup i can only see 1,34 TB on it? I use in USBCOPY the mode Mirroring. Even when i delete everting on the USB Driber, alswas the same same.... Not all Films were copied....
Did you have an old copy of the share on the USB drive that was created using a non-mirrored copy? When I switched to mirror I had to delete older copies. Now the mirror is 100% exactly the same bytes as the original.
I alreade fomate the disk an rebuit a mirror to targe.
