Samba Anonymous Login Authentication
Tell us your most wanted new features, or recommendation.
Hobba
Post by Hobba »
Hey guys,
My old nas had the option for Samba Anonymous Login Authentication, I was hoping you guys could add it to my Terramaster F5-422, preferably in a way I can select it on a per share basis, so I can have a share that doesn't request a password and others that do.
Thanks, Hobba
Re: Samba Anonymous Login Authentication
HI! Enable the guest user, and set the shared folder permissions for the guest user.
Hobba
Post by Hobba »
Thank you, but this still requests credentials when the shares are accessed and requires people to know to type guest into the login, understandable when there's multiple accounts associated with one share, but otherwise a nuisance.
TMAY
Post by TMAY »
Hello, please clear the cache record through cmd.
Press Win+R to open "Run",
Type cmd, press Enter,
Enter net use /del Z (drive letter):, press Enter
Hobba
Post by Hobba »
the problem is with a network share on the tnas, how would i enter a drive letter for this command?
Thanks, Hobba
Enter net use to view your network connection, the drive letter corresponding to the network connection will be displayed.
Hobba
Post by Hobba »
my tnas isnt showing up when i run net use in cmd.
I set up a share with guest access only and its still requesting login credentials.
Thanks, Hobba
Hobba
Post by Hobba »
hey guys, I found my problem, I had no permissions set for the guest account, I had assumed by allowing all users that the guest account would receive permissions from that, but makes sense for security.
Thanks for the help,
Hobba
Return to “New Features Wanted”
