TOS 4.2.17 is released for update
brunix86
Italy
Re: TOS 4.2.17 is released for update!
Post by brunix86 »
Charlie_Croker wrote: 08 Nov 2021, 16:46 Update, despite my earlier posts, I can now confirm Smart Fan Control is broken, setting fan to high is the only setting where I can be (90%) confident it won't drop to 10RPM.
I can confirm that Low-Mid-Hi fan speeds always work fine.
The problem occurs only with Smart fan speed: after some seconds\minutes the speed will be set to 10 RPM.
But this behavior is random, because now it works fine also with Smart fan speed setting (for at least 2 hours) and I don't know how to replicate this scenario.
My NAS Environment
  • TNAS F4-423
  • TOS 5.1.123-00529 (8GB System Partition)
  • 2x RAM Terramaster 4GB DDR4 2133 MHZ
Jac de Lad
Post by Jac de Lad »
My mid speed fan goes to 20 rpm after a while. Case is 34°C, HDD is 46°C (sometimes even higher). IMO medium should be medium speed all the time, not until a certain temperature is reached. Also smart should take a look at the HDDs too, not Just the case temperature. Just my two cents.
deejc
Post by deejc »
can confirm, that actually mine is exhibiting the same issues, fan is set to smart
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
billyBob
Post by billyBob »
using 4.2.17 with fan patch
when you use the internal file manager and transfer 500 gigs or more to an external usb device, the entire system locks up and you have to reboot :(
I don't know the exact amount that I transferred but this is second time, moving large data sets and the entire nas needing to be rebooted.
deejc
Post by deejc »
The lock ups are not limited to using internal tools I was copying a few gigs of data using AFP last night in 2 or 3 different threads and the nas locked up more than once but luckily for me it didn’t need a reboot just to wait for a few minutes
sports_wook
Post by sports_wook »
I copied 1.5 gigs over SFTP without issue yesterday. Maybe wasn't large enough to lock the system up, but worked fine for me. 4.2.17 with the patch applied.
{L_BUTTON_AT}billyBob
as you were reading from your TNAS and writing to your USB, This is probably because your USB device was not responding, causing the system to keep sending requests but not responding, and thus it hangs temporarily.
deejc
Post by deejc »
Mine wasn’t usb it was from mac OS X across the network at about 10MB according to the software I was using and using AFP
AdoVisuals
Post by AdoVisuals »
After overheating my HDD I update my T5-422 from 4.2.16 to 4.2.17. And I keep eye on temperatures on system and in beatween HDD add digital termometer. I see that HDD temperature in TOS system is 54C but on digital termometer 42C. System temperature 46C. Fans ar on maximum speed. Ambiant teperature is 22C. Something wrong here... :? In system I think disk temperature just stuck...
F5-422 5x6TB IronWolf Pro, RAID5, 10Gbe
TD2 Thunderbolt 3, 2x6TB, IronWolf Pro
Charlie_Croker
Post by Charlie_Croker »
{L_BUTTON_AT}AdoVisuals
You need to install the patch, its here viewtopic.php?f=28&t=2640 The enclosure speed (Digital Thermometer) will be lower than your drive temperature due to heat dissipating from the enclosure, inside the enclosure, heat cannot escape. (like coolant in a car can be 115C, while temperature of piston head would be around 2-3x higher.)
