Hello Team,
i have tried to change the PHP-Version in the Webserver App. Per default the Webserver is using PHP 7.1.
I´m able to start the Webserver and create a virtual Host with PHP 7.1 and can run PHP programms (under 7.1).
But if i try to add a higher PHP version like 7.4 in the PHP-Settings i´m not able to assign this higher version into the webserver. After i changed the PHP Version and save it (independently on general settings or the virtual host settings) it switch back automatically to PHP 7.1.
If i delete the PHP 7.1 default version in the PHP-Settings and assign again the higher version for example in the virtual host, it says "not configured" and i cannot run any PHP-Programs anymore. Can you please help?
I using the F2-422 with TOS 4.2.08
Kind regards
Gryphus
Webserver PHP-Version change not working
Re: Webserver PHP-Version change not working
thank you for your report. as we are in holiday this week, will verify it within next week. by the way, it is recommended to update your TOS to the latest version.
I see this was never replied to and is immediately related to my recent post in this subforum as well.
Please update your TOS and web Server app to the latest version.
Already on latest version, thank you.
