Moodle
pedfuego
Moodle
Post by pedfuego »
Is anyone using Moodle on a TerraMaster NAS?
I have tried to install it using MariaDB and the WebServer installed on the system, but there are compatibility issues with the installed versions. Also, PHP is missing some extension.
I've also tried it with Docker, but I'm afraid I'm doing something wrong and can't get it to work.
Someone who has succeeded ?. Any advice?
Re: Moodle
If you have an x86 TOS you can give it a try
viewtopic.php?f=37&t=2497
Return to “Others”
