[ Traccar ] Free and open source modern GPS tracking system
Hardfecx
Re: [ Traccar ][ 4.14.0.0 ] Free and open source modern GPS tracking system
Post by Hardfecx »
Thank you, I will try it
Hardfecx
Post by Hardfecx »
Well, the configuration file is still empty. On my Android devide i copied the "Geräteerkennung" to configure the device in Tracecar. But on client I only get "Übertratung fehlerhaft" and in the Traccar app, my device is offline...
We can try a teamviewer because is something that i don't understand as first you said that you have all the options from my screenshoot and later you said the config is empty.
Have you open the port 5055 on your router ? (port forward)
You can test here if the port forward was done correctly
But before you can try it from outside the network (via internet) you can test the connection via local network.
1. On traccar client android on your phone go to Server URL option and type:
http://yournasip:5055
2. Toggle service status to on
3. Go to Traccar Server web interface on your NAS, on top left corner click on + next to Devices to add a new device
For Name choose anything yu want
For Identifier, type the Device Indentifier value from traccar client on your phone
4. Type additional info if you want
5. Save the new device
The device should come online in a few seconds
Hardfecx
Post by Hardfecx »
outkastm wrote: 20 Oct 2021, 03:30 We can try a teamviewer because is something that i don't understand as first you said that you have all the options from my screenshoot and later you said the config is empty.
[/code]
[/code]
sure we can do a teamvieuwer session, I'll send you my ID vie PN
Hardfecx
Post by Hardfecx »
My Port is open in the router on my IP Adress, gave my "Phone ID" in the App, but still the same error...
Hardfecx
Post by Hardfecx »
I have another questoin: How to get a traceline on the live Map? For the moment when I go out, the card only follows my gps signal but don't left a line on the way i was gone?
May someone help me?
just expand the report section on the bottom of the web interface
and play with the different options for reports
Hardfecx
Post by Hardfecx »
{L_BUTTON_AT}outkastm
Thank's M8 for your help. is exactly what I searched! TY
