Why did they stop supporting BTRFS?
SquarePeg
Wales
Post by SquarePeg »
Does anyone know why? It is superior to EXT4 but if you want the latest security holes patched, you have to install the newer OS and lose BTRFS!
Re: Why did they stop supporting BTRFS?
Because of technical issues, btrfs has already been removed from the ARM series models like F2-210/F4-210. The x.86 models keep supporting btrfs.
SquarePeg
Wales
Post by SquarePeg »
TMroy wrote: ↑04 Sep 2021, 23:32 Because of technical issues, btrfs has already been removed from the ARM series models like F2-210/F4-210. The x.86 models keep supporting btrfs.
What technical issues? BTRFS was working fine. I use BTRFS on my home PC and it is rock-solid.
Saijin_Naib
Post by Saijin_Naib »
{L_BUTTON_AT}SquarePeg
We're using a pretty back-level kernel on the ARM units and there have been an absolute boat-load of really critical fixes to BTRFS that are simply not present in the kernel we're using.
I had asked (and continue to hope) that we get on current 5.10 LTS so we get those fixes and BTRFS might become a safe option again, but my hope is low.
SquarePeg
Wales
Post by SquarePeg »
Saijin_Naib wrote: ↑08 Sep 2021, 03:25 We're using a pretty back-level kernel on the ARM units and there have been an absolute boat-load of really critical fixes to BTRFS that are simply not present in the kernel we're using. I had asked (and continue to hope) that we get on current 5.10 LTS so we get those fixes and BTRFS might become a safe option again, but my hope is low.
Thank you for your reply. I hope they will include it in the new release.
mukmuk
Post by mukmuk »
{L_BUTTON_AT}TMroy
Is it safe for me to further use BTRFS on (x86) F2-221 or should I think about resetting the unit? I've set it up through the installer on a former version of TOS (4.0.x or was it 4.1.x already? Not sure anymore). Resetting would be my least preferred option... :/
you need to update your TOS to the latest version, there are so many bugs fixed from 4.0.xx including btrfs support, 4.0.x is too old.
mukmuk
Post by mukmuk »
Yeah, I do know that. My F2-221 is on 4.2.14-P1.10 at the moment. The question however was, if I can safely stay with BTRFS on the long run (as in: for example for TOS5 etc).
Yes, why not?
Rice
Post by Rice »
Are there any security issues if we continue to use BTRFS on drives already set this way?
Terramaster removing this has me worried, particularly that it is no longer supported
