http://www.lan-play.com/
Last version: v2.0.0-rust.alpha.11
Applicable models: TerraMaster x.64 series, TerraMaster arm series
Applicable TOS: 4.1.27 or later versions
App download:
x86: https://bit.ly/3iieauE
amd:https://bit.ly/3xJNLfv
WebUI for additional informations can be access by
http(s)://yournasip:11451/
How to manually install this app on TerraMaster application store? viewtopic.php?f=37&t=1482
Switch Lan Play Server can help you to make a virtual lan, so you can play game with your friends. More information about how to use it please refer to above website.
This app has been tested with F4-221.
About : [Switch Lan Play Server][v2.0.0-rust.alpha.11] Make you and your friends play games like in a LAN.
Re: [Switch Lan Play Server][v2.0.0-rust.alpha.11] Make you and your friends play games like in a LAN.
on version 4.1.27 it stops working after reboot on version 4.2.14 the message is not installed incorrect file format
I figured out the installation only in the Angdian language. if you can lay out detailed instructions for setting up
