[ Cron_okm ] Time-based job scheduler
Re: [ Cron_okm ][ 1.5.7.0 ] Time-based job scheduler
Hardfecx wrote: 01 Jan 2022, 05:55 is there a possibility to get an arm version?
should be feasible
Hardfecx
Post by Hardfecx »
Thank you M8
added arm version
jdalconchel
Post by jdalconchel »
Does it really work?
Seems not to be working.....
your question is for arm or x86 version ?
arm version was not tested as i don't have a NAS with this platform
jdalconchel
Hi, thanks for your quick response and this development. I'm glad to say It works fine (x86).
Mordac85
Re: [ Cron_okm ] Time-based job scheduler
Post by Mordac85 »
Has there been a change or is there some kind of incompatibility with TOS 5.x?
I need to run a task more frequent than every hour so the new Scheduled Tasks feature isn't going to work, but I keep getting a "file is incorrect and cannot be installed" error when trying to manually install Cron_okm_V1.5.7.0_x86_64.tpk
F5-221
TOS 5.1.67
4 x 4TB RAID5 EXT4
1 x 8TB EXT4
TOS4 apps cannot be installed on TOS5.
I will port this to TOS5 in a few days
Mordac85
Post by Mordac85 »
Thanks, I appreciate it.
F5-221
TOS 5.1.67
4 x 4TB RAID5 EXT4
1 x 8TB EXT4
added TOS5 version
