will you release 10.8.12 version for x64?
[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ] The Free Software Media System
It is already released (TOS5)
hi, 10.8.13?
{L_BUTTON_AT}outkastm
I need help setting up Jellyfin on my new TerraMaster F2-223.
Trying to access via Fire TV & TCL Roku TV & Chrome browser.
None work. Please help!
I used this video to guide me: https://www.youtube.com/watch?v=eihck4lpf5U
TerraMaster F2-223.
TOS 5.1.103-00409
1st I installed:
Jellyfin TOS5 10.8.12.0 x86_64
2nd:
ffmpeg51 TOS5 5.1.3.0 x86_64
3rd
ModBase1 TOS5 1.00.16_x86_64
Jellyfin and ffmpeg51 both said that the ffmpeg app wasn’t installed, so I installed:
ffmpeg TOS5 4.4.3.2 x86_64
I turned on Hardware acceleration and ticked several boxes but keep getting playback errors and client device not compatible errors.
Today I noticed that some new versions are available, so I uninstalled everything and did this:
1st I installed:
Jellyfin TOS5 10.8.13.1 x86_64
2nd:
ffmpeg51 TOS5 5.1.3.1 x86_64
3rd
ModBase1 TOS5 1.00.17 x86_64
I was surprised to find that I wasn’t prompted to go through the setup process and my library and hardware acceleration selections persisted the uninstall / re-install.
Sadly, no changes in errors.Re: [ Jellyfin ] The Free Software Media System
Try to set up English interface in your TOS installation before installing all those apps
If you want to remove Jellyfin config, stop the app and remove the config folder as below using the file manager
Thanks, that did get rid of my old configuration and now I have re-installed Jellyfin but it can't seem to connect to the server anymore.
I will un-install everything and start over again.
Is there a particular order the apps like ffmpeg and ModBase need to be installed?
Which hardware acceleration methods should I choose for my F2-223?
- dianzisongyang
Thank you for making this app.
I have all the dependencies installed, gave Jellyfin user group MEDIA access.
Jellyfin can see a lot of my files and fetched art/info.
Final problem: it will not play any files. Chrome, android app, etc.
See attached image for error client-side.
I have log files if you need. Very long. Anything particular you want from log?
My TerraMaster NAS is CPU is . Should use QSV, yes?
F2-221
J3355
- Attachments
- jellyfin error.png (22.54 KiB) Viewed 562 times
