World Backup Day – Don’t be an April fool. Be prepared. Back up your files on March 31st
What is Backup?
Backup refers to the copying of physical or virtual files or databases to a secondary location for preservation in case of equipment failure or catastrophe. A backup is a second copy of all your important files — for example, your family photos, home videos, documents and emails. Instead of storing it all in one place (like your computer), you keep another copy of everything somewhere safe.
But Why Should I Backup?
Losing your files is way more common than you’d think. Ever lost your phone, camera or tablet? That counts. Your stuff could have been saved with a backup. One small accident or failure could destroy all the important stuff you are about.
The computer could stop working at any time, and if the hard drive fails, the data on the hard drive may be damaged or lost. Data on the computer may be lost when the hardware or computer stops working. Any important files should be backed up to prevent data loss and to ensure that they can be recovered if needed.
In addition, backups are often the best choice for an organization to recover from a ransomware attack or a major data loss event, such as a fire in the data center.
So How Do I Backup?
Most people backup their files in one of two ways: to an external drive, or somewhere on the Internet.
It’s really easy, and you only need to set it up once!
Backing up to a USB drive
You’ll need to external hard drive for this, preferably one that holds more than your computer can.
WINDOWS 7
Click the Start button.
Type “backup” into the search box.
Click on Backup and Restore.
Choose “Set up Backup”.
When Windows has finished preparing, select your external hard drive and click Next.
Click “Let Windows Choose” and press Next.
Then click “Save settings and run backup”.
You’re all done! Windows will backup automatically from now on. Make sure you leave your hard drive plugged in, or if you’re on a laptop, set a reminder to plug it in often.
Congrats on setting up your first backup!
WINDOWS 8
Open your start screen and start typing “file history settings”.
In the search results panel, tap or click “File History Settings”.
Tap or click “Select a drive”.
Choose your external hard drive from the list.
Click “Turn on”.
That was easy. Windows will backup all your files automatically from now on. Make sure you leave your hard drive plugged in - or at least plug it in often.
Congratulations on setting up your first backup!
MAC
First, plug in your USB hard drive. Then, follow the instructions below to start automatically backing up your Mac!
Open the menu (in the top left of your screen) and choose System Preferences.
Click on “Time Machine”.
Click “Select Disk”.
Choose your USB hard drive from the list and select “Use Disk”.
You’re done! Your Mac will back itself up automatically from now on. If you’re using a MacBook, make sure to plug in your hard drive regularly so it can save your files!
LINUX
Every Linux distribution offers various tools to backup your data. We’ve posted the instructions for Ubuntu below.
Open the HUD (click the Ubuntu button in the Dash) and type “Backup”.
Click on the search result “Backup”.
Click on “Just show my backup settings”.
Activate “Automatic backups”.
Choose the location to store your backup on the tab “Storage” (your external drive).
Choose how often to backup on the tab “Schedule”. The more often, the
better!
Click on “Back Up Now” on the tab “Overview” to start backing up.
That was easy. Ubuntu will backup all your files automatically from now on. Make sure you leave your hard drive plugged in - or at least plug it in often.
Backing up online
A simple way to start saving your files to the internet is by using OneDrive, Dropbox, Google Drive, or even Amazon Cloud Drive to backup the most important things you’re working on right now.
These “online drives” usually don’t have too much space, and only backup one folder on your computer. However, this is great for students and businesspeople who need to keep their most important documents safe.
If you’d rather back up absolutely EVERYTHING (good on you!) - just search for “online backup reviews” on your favorite search engine. It can help you choose the service that’s right for you.
This article is reprinted from: http://www.worldbackupday.com/en/
TO CELEBRATE WORLD BACKUP DAY!
HELPFUL TIPS ABOUT DATA BACKUP SOLUTION-NAS(1/3)
TerraMaster Personal/Home NAS F4-210 Advantages
1. Help you store and manage photos
2. Automatically backup all your data away from data lost.
3. Supports watching videos on TVs, mobile phones, tablets, and computers, and easily share them with friends and relatives
4. Give you complete control over the stored data
5. Has a remote access anytime and anywhere to get data
HELPFUL TIPS ABOUT DATA BACKUP SOLUTION- NAS(2/3)
TerraMaster F5-422
10Gb high-speed quad-core NAS
1. High Performance Hardware Configuration
2. Ten times standard bandwidth
3. Supports Multiple Raid Modes
4. Extensive Backup Options
5. Supports Synchronisation of Multiple Cloud Drives
6. Supports various Enterprise Applications
7. Multilayer Safety Protection
HELPFUL TIPS ABOUT DATA BACKUP SOLUTION- NAS(3/3)
TerraMaster F2-210 just for you:
The most powerful 2-bay NAS under $150
Quad-core 1.4GHz CPU, 1GB RAM, and all-aluminum shell
The well-deserved "king of cost performance"!
HELPFUL TIPS ABOUT DATA BACKUP SOLUTION--USB
USB refers to the direct connection of storage devices to the target computer or server through various interfaces. Here comes the recommendation of TerraMaster D5-300C:
1. Exclusive 2+3 RAID Storage
2. Real SUPERSPEED with USB3.1 Protocol!
3. USB Type-C interface
4. Up to 90TB storage capacity
5. Support various applications
HELPFUL TIPS ABOUT DATA BACKUP SOLUTION-- THUNDERBOLT3 RAID STORAGE
TerraMaster D8 Thunderbolt 3:
1. 40 Gbps Lightning-Fast
2. Professional-Grade Hardware RAID
3. High scalability with daisy-chain function
4. Rapid Video Workflows
5. Reliable and Safe
6. Perfectly Suited for the Most Demanding Video Professionals
WHAT IS BACKUP? HOW DO I BACKUP?
- TMsupport6
- TerraMaster Team
- RobertDoxon
Re: WHAT IS BACKUP? HOW DO I BACKUP?
Congratulations to all.
Hello. How do I set up an automatic backup of a photo from my phone (android)? (F2-223? TOS 5.1.24)
TNAS: F2-223, 32GB Ram, TOS 5.1.41, 1x3TB WDRed ext4
There is no automatic backup function for the time being. We will implement this function later.
You just posted in the wrong forum section.
TM offers a mobile app called TNAS mobile, you can backup your photos to your NAS with the app.
