[ Nextcloud ] Self-hosted productivity platform
Re: [ Nextcloud ][ 24.0.2.0 ] Self-hosted productivity platform
{L_BUTTON_AT}sanctimon
you can use Cron_okm and your config file will survive a reboot viewtopic.php?f=37&t=1821
sanctimon
Post by sanctimon »
Thank you, I am looking into that! ;)
Do you know if there will be an updated version of Nextcloud soon?
Re: [ Nextcloud ] Self-hosted productivity platform
up to 24.0.2.0 and added TOS5 version
up to 25.0.0.0
sanctimon
Post by sanctimon »
Hello! thanks for your hard work and support so far. Any news on 25.0.0.3?
up to 25.0.3.0
sanctimon
Post by sanctimon »
Thank you, will there be a TOS4 version, too?
low priority for updating TOS4 apps
CaptainKanuk
Post by CaptainKanuk »
{L_BUTTON_AT}outkastm
I am having trouble with the line "Go to module WebUI and from menu choose Configuration files >> Edit php.ini
Add this line apc.enable_cli = 1 at the beginnig of the file as below (if is not already there): "
when I go to help and support, i can get to the php.ini file but it is read only (for PHP81_okm). How do I edit the config file?
I just got my F5-221 on the weekend, intalled TOS5.1, and now trying to install NextCloud.
PHP81_okm app doesn't require any change.
You have to follow these steps from Nextcloud_okm app, but if is a new installation the option is already there.
