[ Syncthing ] Continuous Replication/Cluster Sync
super-6-1
Re: [ Syncthing ][ 1.20.4.0 ]Continuous Replication/Cluster Sync
Post by super-6-1 »
Can't seem to get the web gui to load. I'm not seeing issues in the logs just says can't connect. TOS 5 newest build. I have uninstalled, reinstalled, restarted, cleared the config. Any ideas?
super-6-1
Post by super-6-1 »
super-6-1 wrote: 20 Oct 2022, 08:13 Can't seem to get the web gui to load. I'm not seeing issues in the logs just says can't connect. TOS 5 newest build. I have uninstalled, reinstalled, restarted, cleared the config. Any ideas?
fixed the issue
Re: [ Syncthing ] Continuous Replication/Cluster Sync
up to 1.22.0.0
Nodsert
Post by Nodsert »
outkastm wrote: 27 Oct 2022, 01:19 up to 1.22.0.0
Hi, the package to armv8 is damaged. Fail to install.
Thanks.
kimiforein
Post by kimiforein »
Mostly its TOS5's fault...I only get 502 Bad Gateway nginx/1.18.0 when I click the Syncthing icon on the TOS webui desktop.
And thanks for you work, It has been working perfectly before the recent TOS update...
Have you tried to install again ?
Nodsert
Post by Nodsert »
outkastm wrote: 31 Oct 2022, 02:36 Have you tried to install again ?
Yes, but I can't get it to install...
remove the white spaces from filename and try again to install
Nodsert
Post by Nodsert »
That was the problem. Thanks!
