How to manually install 3rd Party Apps and the list with available apps
TM220user
Re: How to manually install 3rd Party Apps and the list with available apps
Post by TM220user »
@outkastm
If I could add a request to the list (either separately, or as part of the ModBase1 collection):
apt (the package manager)
TIA
F2-220 (x86 flavored!)
lthirion
Post by lthirion »
Prowlarr is not starting and the log says this:
Warning: fopen(/mnt/appdata/MOD_CONFIG/Prowlarr/.config/Prowlarr/logs/prowlarr.txt): failed to open stream: No such file or directory in /usr/www/modules/Prowlarr/www/6.php on line 86
There must be a missing file or maybe there is an improper reference. I tried the most recent version (v0.4.1.1838.0) as well as the last one (v0.3.0.1730.0) and got the same result.
Thanks for all of your work btw :)
hollyt9
Post by hollyt9 »
Can Modbase and apps dependant on Modbase be installed on the F2-420?
The F2-420 doesn't appear in the x64 series list, even though it's a Celeron 2.0Ghz quad core.
I'm pretty desperate to install Jellyfin but want to check if the F2-420 is supported before installing Modbase
cpeb
Post by cpeb »
Afternoon OutkastM
Modbase and Python installed before i installed Sickchill but Sickchill won't start.
Config file only has the webport in it and all the logfiles show the same message.
<br />
<b>Warning</b>:  fopen(/mnt/appdata/MOD_CONFIG/SickChill/DATA/Logs/sickchill.log): failed to open stream: No such file or directory in <b>/usr/www/modules/SickChill/www/4.php</b> on line <b>87</b><br />
TOSv4.2.39
I manually created the log files which got rid of the above error and even installed webmin to help me try and find a solution as none of the logs actually log anything for it.
If the log is missing or empty, it means syckchill has never started. Do you have the knowledge to connect with SSH for troubleshooting ?
cpeb
Post by cpeb »
Morning,
Intermediate knowledge of LNX, if there's something i need to check let me know and i will figure it out. First thing i did was install webmin to try and check the logs but nothing showed that would help.
cpeb
Post by cpeb »
{L_BUTTON_AT}outkastm
Did you see my previous post?, let me know what you need. Thanks
lthirion
Post by lthirion »
In case anyone is having the same problem I mentioned in my last post, My current workaround is to host Prowlarr in a docker container.
@cpeb, you might be able to do the same thing with SickChill.
lthirion wrote: 12 Aug 2022, 13:40 Hi,
The start issues is fixed, if you still need it you have to download again the app and install it
