[ Sabnzbd3 ] Usenet Grabber
PriestyUK
Re: [ Sabnzbd3 ][ 3.6.0.0 ] Usenet Grabber
Post by PriestyUK »
Morning Outkastm,
Thanks for the update, do you know how to fix these errors since installing the update?
It seems that I need to update also some python modules. Will be done later today
PriestyUK
Post by PriestyUK »
Legend 🤛🏻
download and install again the latest version
PriestyUK
Post by PriestyUK »
Dam i'm getting this error, tried unistalling as well but get the same error:
Hmmm, my local file was installed with no issue. I will download the file from gdrive and check that one.
Could you maybe check the previous version and see if that one will install correctly?
PriestyUK
Post by PriestyUK »
Sure ill do it now :D
PriestyUK
Post by PriestyUK »
Ok I think i've worked it out, because I had downloaded 2 of the same filename the new one was called Sabnzbd3_V3.6.0.0_x86_64.tpk (1) and it must not have liked it
Testing now and it doesn't seem to be anymore errors, downloads have resumed. WELL DONE :D
Reason: Areas misstype instead of errors
Great!
PriestyUK
Post by PriestyUK »
Errors not Areas lol :lol:
