[ Radarr ] Fork of Sonarr for Movies
Re: [ Radarr ] Fork of Sonarr for Movies
installed the latest version 4.3.2.6857.1 and check the start.log
jhalfhide
Post by jhalfhide »
outkastm wrote: 05 Feb 2023, 18:07 What is your TOS version?
5.1.13-00292
F2-422 running TOS 5.1
Plex/Sonarr/Radarr/Lidarr/SabNZBD
jhalfhide
Post by jhalfhide »
outkastm wrote: 05 Feb 2023, 22:52 installed the latest version 4.3.2.6857.1 and check the start.log
Unable to do that, as the application never starts. Are there local logs stored in the filesystem? I also have the same issue as in another post, whereby I only get 502 Bad Gateway pages when clicking on community applications. This goes for all community applications. Plex was the same, until I switched to the proper Plex TOS5 release, then it works as expected.
if you press on Support & Help you get the same 502 error ?
jhalfhide
Post by jhalfhide »
{L_BUTTON_AT}outkastm
I get 404 Not Found nginx/1.18.0 instead.
maybe we can have a teamviewer session to check
jhalfhide
Post by jhalfhide »
Happy to, and ready whenever you are.
try one more thing before teamviewer
In ssh run
rm -rf /usr/local/Radarr/bin
Reinstall the latest version
jhalfhide
Post by jhalfhide »
ok, I managed to get it working. I did have to do a complete uninstall of Radarr, including configuration. I then installed the latest version and it opened right away. It must have been some config corruption. Just finished setting it all up again.
JenishJohn12
Post by JenishJohn12 »
Okay so i finally singed it to download my fav movies but it pretty much same as CouchPotato.
