Hi all,
Does anyone know if it is possible to create two targets pointing to the same LUN and thus be able to create multipath from ESXi?
Thankyou.
Regards
Two iSCSI targets on same LUN
Re: Two iSCSI targets on same LUN
You may try with iSCSI Pro to see whether it's ok.
Ah, Ok
Thanks.
Regards.
Thanks.
Regards.
