OpenClaw Beta Version Now Available on the ARM Platform
TMketheric
Post by TMketheric »
Hello everyone! The OpenClaw Beta version is now available on the ARM platform. This release focuses on ARM platform compatibility and further expands OpenClaw's hardware compatibility. Users of supported ARM models can now install and experience OpenClaw.
Supported Models and Operating Limitations
  • OpenClaw currently supports only the F2-213 and F4-213 models on the ARM platform.
  • OpenClaw has certain performance requirements for the host device. Older models such as F2-211, F2-212, and F4-212 do not meet these requirements and cannot run this application. To ensure a good user experience, do not install the application on unsupported models; otherwise, doing so will result in system lag, poor responsiveness, and other issues.
Important Notes
  • This version is in the OpenClaw Beta testing phase and may contain unknown functional defects and stability issues. It is intended for testing and feedback only. Do not use it to store important data, in production environments, or for official business scenarios.
  • Under normal circumstances, installing this application will not affect existing data already on the hard drive, but potential risks cannot be completely ruled out. Before installation, be sure to back up all important data and verify that the backup can be restored properly.
  • This application has elevated system permissions. Do not modify critical system settings, format disks, make bulk permission changes, or perform other high-risk operations. If an issue occurs, first check the status of the current task, avoid further high-risk operations, and report the issue promptly.
Full Update Details
Platform: TOS 7.0 (ARM)
Application version: 0.0.308 (ARM)
Update Contents
1. Upgraded OpenClaw and Node.js.
2. Optimized the OpenClaw service restart policy.
3. Updated support for OpenClaw's new model data mechanism.
4. Improved gateway service stability.
5. Optimized initialization and rollback features.
6. Reduced background resource usage.
7. Fixed several known issues.
Installation
Go to TOS > App Center > Utilities, locate the OpenClaw application, click "Install" and follow the on-screen instructions to complete the installation.
Bug Feedback
Thank you for taking the time to help us test OpenClaw! Every piece of feedback is an important step toward the official release.
As this is a Beta release, some issues are expected. Please do not publicly disclose information about defects in the Beta version, as this may cause unnecessary concern.
To report a bug, please send a description of the issue, reproduction steps, and relevant screenshots to: [email protected].
