I started a long S.M.A.R.T.(SMART) test in my F4-425, having no idea it would be so long. The 8TB drive completed in about 36 hrs. The 10 TB drive and 16TB drives are still testing.
About how long does a SMART test take? Is there a way to abort and do a short test?
How long does a long S.M.A.R.T. (SMART) test take? [SOLVED]
- ShoutingMan
Re: How long does a long S.M.A.R.T. (SMART) test take? [SOLVED]
Regarding the questions you raised:
1. How long does an extended S.M.A.R.T. test take?
An Extended (Long) test performs a complete surface read scan of every sector across the entire disk. The duration scales with capacity and drive speed (typically 1.5 to 2.5 hours per TB for mechanical HDDs under idle conditions):
- 10TB drive: Typically 18–25 hours.
- 16TB drive: Typically 28–40 hours.
2. Can you abort the test and switch to a short test?
Yes, you can abort an ongoing test at any time without risking data loss:
- Go to Storage Manager > Disk > S.M.A.R.T., locate the drive currently running the test, and click Stop.
Hope this helps!
- ShoutingMan
A 16TB drive finished up sometime last night, about 6 days duration. Two drives ongoing.
