Since I have already setted up Jellyfin with Docker Manager image/container, someone told me to do the following to edit the container steps to enable hardware transcoding:
1) Enable high permission to execute the container. (This is below the Enviroment Variables)
2) click the Add button in the Environment Variables section and type in these exact fields:
Key Value
PUID 1000
PGID 1000
TZ America/Toronto (or your actual local timezone city)
3) Goto Jellyfin and turn on Intel QuickSync inside Jellyfin settings.
Is this correct since I have no experience with Jellyfin and F4-424 with Docker manager. Thanks in advance.
Need help to confirm how to enable hardware transcoding on Docker Manager Contariner Jellyfin (Solved)
F4-424
Two D4-320
Two D4-320
Re: Need help to confirm how to enable hardware transcoding on Docker Manager Contariner Jellyfin
F2-424 TOS7.0.1341 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1422 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1341 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
Does not matter as long as the log is now the right time, it was about 8 hours ahead.
F4-424
Two D4-320
Two D4-320
Finally found out how to do it, need to create a project and add the following to it and only need to change to adjust it to your settings, it is working now.
version: '3.8'
services:
jellyfin:
image: jellyfin/jellyfin:latest
container_name: jellyfin
restart: unless-stopped
network_mode: 'bridge'
environment:
- PUID=1000
- PGID=1000
- TZ=America/Toronto
ports:
- 8096:8096
- 8920:8920 # Optional HTTPS port
volumes:
- /Volume1/public/jellyfin/config:/config
- /Volume1/public/jellyfin/cache:/cache
- /Volume1/public/media/movies:/movies
- /Volume1/public/media/tvshows:/tvshows
devices:
- /dev/dri/renderD128:/dev/dri/renderD128 # Enables Intel Quick Sync hardware transcoding on F4-424
version: '3.8'
services:
jellyfin:
environment:
- PUID=1000
- PGID=1000
ports:
- 8096:8096
volumes:
devices:
F4-424
Two D4-320
Two D4-320
