TOS 7.0.0567 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank users @nedhedrick, @Felix, @rfbjr, @OttO1916, @NogO, @Nitrokalel, @Joesh, @luismartin, @rage, @Gremlin, @samius, @nikk, @EriChan and others for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixed:
1. Fixed an issue where the number of updatable applications in the App Center might be inconsistent with that in the navigation bar.
2. Fixed an issue where editing file service mount permissions for a shared folder might display incorrectly.
3. Fixed an issue where the subtitle on the login page was not centered.
4. Fixed an issue where NFS remote folders could not be edited properly.
5. Fixed an issue where some languages were missing when entering a password.
6. Fixed an issue where creating a storage pool using an encrypted USB device failed.
7. Fixed an issue where the dashboard did not change after clicking the desktop dashboard settings.
8. Fixed an issue where the resource dashboard displayed incompletely when first entering the desktop.
9. Fixed an issue where a pop-up window indicating data retrieval failure appeared when inserting a USB device.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.540 for Windows OS.
- MD5: AFB7CD77DE2A4F0434D69D52D15959AF
2. Download TNAS PC 5.2.540 for macOS (x86 architecture).
- MD5: 715FEB00FDB06DF4CC9A228622566F70
3. Download TNAS PC 5.2.540 for macOS (ARM architecture).
- MD5: A6954F192DD23AF7374CF2AF20190B6C
4. Download TNAS PC 5.2.540 for Linux.
- MD5: A5B13A2C2C9B0F9FFFCBDF6F3BA9E342
5. Download TNAS Mobile 3.5.064 for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
Lex
Re: TOS 7.0.0567 Beta (X86) is Released for Update
Post by Lex »
Update ok. But locale in docker is incorrect
F4-423
Felix
Post by Felix »
Lex wrote: ↑07 May 2026, 15:14 Update ok. But locale in docker is incorrect
The issue of the "Your Docker service is running normally" message in Docker Manager version 2.2.004 being incompatible with the system language has been fixed. A new version of the application will be released later to resolve this issue.
F2-425+ Updated. No obvious anomalies except the desktop icons/nav bar failed to appear. Normal browser (Firefox) refresh did not make a difference (twice) had to use the desktop F5 option to fix.
rfbjr
Post by rfbjr »
F4-425 Plus and F6-424 updated.
EDIT: Both were updated via the mobile app on my iPhone.
Later in the morning via the webgui showed no issues.
F6-424 & F4-425 Plus at 7.0.1278
F4-424 Pro (x2) at 7.0.1278
rfbjr
Post by rfbjr »
Two logrotate conf files aren't working. Yes I understand if you don't have debug.log files, it's not a concern or don't use openswitch, but the conf's should be able to run without syntax errors.
Molly@Anna:/# ls -la /etc/logrotate.d/
total 32
drwxr-xr-x   2 Molly Molly  4096 May  7 00:43 .
drwxr-xr-x 137 Molly Molly 12288 May  7 00:46 ..
-rw-r--r--   1 Molly Molly    77 May  4 08:13 cloudsyncd
-rw-r--r--   1 Molly Molly   249 May  7 00:43 debug.conf
-rw-r--r--   1 Molly Molly   413 May  7 00:43 openvswitch-switch
-rw-r--r--   1 Molly Molly   117 May  7 00:43 syslog.conf
Molly@Anna:/#
Molly@Anna:/# journalctl -u logrotate.service
May 07 01:00:01 Anna systemd[1]: Starting Rotate log files...
May 07 01:00:01 Anna logrotate[10452]: error: debug.conf:1 keyword 'logpath' not properly separated, found 0x2f
May 07 01:00:01 Anna logrotate[10452]: error: found error in file debug.conf, skipping
May 07 01:00:01 Anna logrotate[10452]: error: openvswitch-switch:1 duplicate log entry for /var/log/openvswitch/ovs-vswitchd.log
May 07 01:00:01 Anna logrotate[10452]: error: found error in file openvswitch-switch, skipping
May 07 01:00:01 Anna systemd[1]: logrotate.service: Deactivated successfully.
May 07 01:00:01 Anna systemd[1]: Finished Rotate log files.
May 07 02:00:01 Anna systemd[1]: Starting Rotate log files...
May 07 02:00:01 Anna logrotate[23439]: error: debug.conf:1 keyword 'logpath' not properly separated, found 0x2f
May 07 02:00:01 Anna logrotate[23439]: error: found error in file debug.conf, skipping
May 07 02:00:01 Anna logrotate[23439]: error: openvswitch-switch:1 duplicate log entry for /var/log/openvswitch/ovs-vswitchd.log
May 07 02:00:01 Anna logrotate[23439]: error: found error in file openvswitch-switch, skipping
May 07 02:00:01 Anna systemd[1]: logrotate.service: Deactivated successfully.
May 07 02:00:01 Anna systemd[1]: Finished Rotate log files.
First is just a syntax error and the second, the commands expect to create a new log file, but there is one there already.
Molly@Anna:/# cat /etc/logrotate.d/debug.conf
logpath/*log {
    daily
    rotate 0
    missingok
    notifempty
    dateext
    dateformat _%Y%m%d
    dateyesterday
    sharedscripts
    postrotate
        systemctl restart rsyslog.service
        systemctl restart atop.service
    endscript
Molly@Anna:/# ls -la /var/log/openvswitch/
total 8
drwxrwxrwt  2 Molly Molly   80 May  7 00:45 .
drwxrwxrwt 18 Molly Molly  760 May  7 00:47 ..
-rw-r-----  1 Molly Molly  944 May  7 00:46 ovs-vswitchd.log
-rw-r-----  1 Molly Molly 1232 May  7 00:45 ovsdb-server.log
Molly@Anna:/# cat /etc/logrotate.d/openvswitch-switch
/var/log/openvswitch/*.log {
    daily
    compress
    sharedscripts
    create 640 root adm
    missingok
    rotate 30
    postrotate
    # Tell Open vSwitch daemons to reopen their log files
    if [ -d /var/run/openvswitch ]; then
        for pidfile in `cd /var/run/openvswitch && echo *.pid`; do
            ovs-appctl -t "${pidfile%%.pid}" vlog/reopen 2>/dev/null || :
        done
    fi
    endscript
Shadeofspirit
Georgia
Post by Shadeofspirit »
F2-425 plus
Does not boot after update. For serveral hours there is a notification "Loading..., please wait!"
Both ips (connected to independed networks) are accessable via ICMP (ping).
I had already tried differend browsers, cash cleaning, mobile app, etc.
F2-424 Updated: Similar to my earlier viewtopic.php?p=56445#p56445
I just noticed that when a usb device is mounted, and the dashboard is open, the usb eject dialogue is hidden behind the dashboard panel.
F2-221 Updated. No issues - desktop appeared as normal after login.
:idea: The older, simpler systems work better :idea: :arrow: :roll: :lol:
snapsh0t
Post by snapsh0t »
F2-425+ updated successfully. Jellyfin still works which is always a bonus.
F2-425 Plus, 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
rfbjr
Post by rfbjr »
Just noticed the app count showing updates isn't working on the taskbar. I thought I saw it earlier for the update to Terrasync earlier, but just now I opened the apps and saw the update for Cloudsync pending.
