How to manually install 3rd Party Apps and the list with available apps
Re: How to manually install 3rd Party Apps and the list with available apps
Should have been fixed by now
JoeHolden
Post by JoeHolden »
Hey @Outkastm!
Is there any chance we could get updates on Jackett, Sonarr, Radarr and Ombi?
Thanks in advance! :)
psviteri
Post by psviteri »
Hi Outkastm,
Thanks very much for your effort.
I would love to have an update for the latest version of Home Assistant, as some integrations will not work with the current .tpk version.
Great work
bennythekid
Post by bennythekid »
With SABnzbd, how can I update the launch parameters to change the folder where the config file is located?
With the default config, it has a folder with like 10G but I want to point it to one with a larger size so I can download larger files.
emperorgr
Greece
Post by emperorgr »
Hey @Outkastm!
we got the new F2-212 model with ARM processor and Qbittorent plug doens't get installed, i get error message, we are running 5.1.67 TOS any idea if this will work? do we need to get more apps/libraries installed?
I don't have yet a 212 series NAS.
This is based on new Arm processor and TOS5.
All the apps for TOS4 arm are not compatible with TOS5 Arm.
New apps have to be created from scratch to work on TOS5 arm.
emperorgr
Greece
Post by emperorgr »
hi and thanks for your confirmation. maybe you can add a warning for users that f2-212 ARM devices wont work with 3rd party apps to the download page
If the downloaded app doesn't include in the filename TOS5 arm, it means that it cannot be installed on TOS 5 arm devices.
It is mentioned on the first page of this topic what file to choose for specific device.
Added also the new arm devices
you can try this version for TOS5 arm and see if it works
https://drive.google.com/file/d/1ZZtqtf ... sp=sharing
emperorgr
Greece
Post by emperorgr »
the new build does seem to work and gets installed, now i have to understand how this works, i get a 502 bad getway error message. btw now i saw that Terramaster had already a previous build pre-installed 4.1.7
